The Continental Overhaul Manual says to place pistons on rods with the numbers inside the pistons facing the front of the engine. But these pistons have numbers that point either up or down, not toward the front of the engine.
How about it, engine builders? What kind of problem am I into here?
Thanks in advance. I have an engine on the stand with the pistons on the rods, waiting to have the rings squeezed and the cylinders installed. I'm assuming that these pistons are also cam-ground. I have built over 20 engines and can't remember this issue ever coming up.
We have had the crankcase to Divco, the accessory case to Drake Air, and the crankshaft, cam, connecting rods, and lifter bodies to Aircraft Specialties in Tulsa for rebuilding and yellow tags. We don't want to screw up.
By the way, if you have your crank ground to .020" under, make sure you have the crankcase machined for thrust washers on the front crankshaft journal. We sent the case off first before we had the crank ground, and had to send the case back afterwards to have it machined when we found it required special main bearings.
Thanks, Taylorcrafters.
