NOS Cowling
  • NOS Cowling
    Here are some fit-up photos of putting on a NOS cowling. This was a relatively new cowl made of 2024 aluminum vs the old 3003.
    This is in roughly chronological order showing some of the test fitting and Dzus fastener installation.
    Best Regards,
    Re: NOS Cowling
    More cowling fit-up.
    Best Regards,
      Re: NOS Cowling
      Next batch of cowl photos. We (mostly) used the plastic Dzus retaining grommets because they allow a slight bit of adjustment for less than perfect holes and because you don't need the special tools to use them. These Dzus studs are AJ40 and AF45 with fairly tall springs. The plastic retainers allow you to try and re-fit without a lot of difficulty removing a Dzus stud fully set in a metal grommet. The plastic can be changed out for metal later if desired.
      Best Regards,
        Re: NOS Cowling
        Makes me want to go out and buy new to replace the dinged and bent one on my old girl. Very nice job.
          Re: NOS Cowling
          Beautiful! So Mark, is that a one-piece top cowl? Is there a hinge there I can't see in the photo? Also, not sure if I'm looking at the photo right, but the bottom piece has flush rivets and a strip backing the main part of the cowl instead of a joggle in the cowl material? If so, that makes more sense than trying to get the joggle in the 2024 and it's a neater fit, too. Is that .025 or .032 2024? Looks like you can get away from all of those nasty folded edges with the 2024, too. Sorry for all the questions-- I'm in dire need of a similar rework.
          It looks great!
          Josh
          Bashibazouk AKA Josh Brehm
          BL-65 #1705
          TF #910
          NC47~ South Oaks Aerodrome
          EAA 1423
          Winterville, NC
            Re: NOS Cowling
            Josh,
            I never measured the cowl pieces, but they feel like .032 with the doubler made of .025. Let me say that I have been handling these cowl pieces as though they were made of pure unobtanium. We measure five times and still cringe when we have to make a cut or a hole. I wish these were 3003 aluminum though, because I could weld up a mistake and I could easily anneal a few places, but I'm not being too critical, it is great to have these. It will be a lot of pounding and fussing when I start repairing Doc's old cowlings.
            Doc's original cowling had the edges rolled and bent as you describe, but my own cowling and Doc's NOS cowling use a doubler at the top edge of the lower cowling. I looked at what it would tale to make the older style bends and it would be a bit of work with a large brake. Yes there are flush rivets to attach the doubler and it works very well. Today I will mount the draw bolt latches to complete the job and begin to paint.
            There is a brand new slip hinge in the center of the top cowl doors.
            The air scoop fits nicely over the Brackett air filter, but it is not a scoop design I have seen on any other Taylorcraft. The scoop is certainly easier to make than the older stamped version and it appears that it will be stiff enough to work well.
            Interestingly enough, Doc's old nose bowl was from a Deluxe. The grill wings do not match the curve on this new nose bowl. We are pondering how to make them fit, but I doubt if it can be done safely.
            The doublers at the lower corners of the bottom cowl are home brew design. I have never had a cowling crack with my steel doublers, but my originals were prone to causing stress cracks. Just use care that the rivets don't interfere with the lower boot cowl. The exhaust cut out was not correct and we had to enlarge it slightly too.
            The biggest PITA was lining up the holes for the Dzus fasteners. There is not much forgiveness for misalignment, so it was a lot of fit-cut-fit-cut-fit...
            Best Regards,
              Re: NOS Cowling
              Hate to ask a stupid question. Why is it called a NOS Cowling?
              Dennis McGuire
                Re: NOS Cowling
                New Old Stock.
                I think it means it was produced by the factory and never taken out of the wrapper - Mike
                  Re: NOS Cowling
                  When you write the check for it, you will think it stands for Never On Sale!
                    Re: NOS Cowling
                    Completed but for paint...
                    Best Regards,
                      Re: NOS Cowling
                      Mark,
                      is there a trick for lining up the holes for the dzus fastener holes with the existing holes in the nosebowl and boot cowling?
                      Josh
                      BL-65 #1705
                      TF #910
                      EAA 1423
                      Winterville, NC
                        Re: NOS Cowling
                        Josh,
                        The main trick is patience, but I'm not sure what you are asking. Do you already have holes that just don't want to line up? Or are you fitting new parts that are undrilled? Some nuances to deal with, but here are a few things I learned along the way:
                        It is best to have your chafe strip installed before measuring for where the holes go. The extra thickness can change the hole alignment about 3/16 inch.
                        It is really good to line up ONE hole on each side of the aft part of the lower cowl, drill and set Dzus fasteners and THEN go on to the next hole, drill and set fasteners, etc. If you try to do all six aft holes all at once it is too easy to accumulate errors and miss-drill a hole.
                        I made a hole finder that works just like a rivet hole finder, except I had a ground-down number 5 stud on the probe end instead of a 1/8 rivet.
                        IF YOU ARE OFF JUST A LITTLE... Don't sweat it! Use the plastic Dzus grommets to hold in any fasteners that are off just a tad. The plastic grommets allow about 3/32 of movement in the stud and you have a slightly adjustable installment. If you use the full metal Dzus grommets you don't have any wiggle, although the full grommets give a better wearing surface for the stud - it is a trade-off.
                        Studs AND springs come in different lengths/heights. It is good to have an assortment on hand. My cowl is all done with AJ5-35, but we needed some 40s and 45s for Doc because of different spring heights and such.
                        Hope that helps.
                        Best Regards,
                          Re: NOS Cowling
                          Thanks, Mark.
                          Apologies for the vague question.
                          Yup, I'm trying to figure out how to make a new cowl to replace my old, cracked one. The challenge of lining up the new dzus grommet holes on the cowl pieces with the existing springs/holes on the boot cowl and the nose bowl.
                          The idea of using an old fastener modified to mark the back side of the cowl pieces makes lots of sense. Also, the idea of doing one at a time is a logical decision-- sort of like using clecos. Thanks for the heads up re: the chafe strip, too!!
                          Josh
                          PS. Nice spark plug cups, BTW!! That cowl is gorgeous. Nice and tight and no bumps!!
                          BL-65 #1705
                          TF #910
                          EAA 1423
                          Winterville, NC
                            Re: NOS Cowling
                            Who makes them?
                            jack
                              Re: NOS Cowling
                              I agree pretty much with everything Mark said except using the chaffing tape when fitting and marking. I did that once on a cowl and it was easy to install right from the start. However after the chafe tape seated in after a while the cowl started to open up some very small,very noticable gaps especially around the nose bowl. I used 2 layers of good quality 3M masking tape in place of where the chafe tape goes. The 3M gives you protection from scratch's,the double layer of 3M is about half the thickness of new chafe tape(almost as thick as it will be once it seats in) . After your holes are drilled and everything is fitted and finished then you will put your chafe tape in place and I will admitt that lining up your holes the first time or two will probably take someone to help because that are a little touch. However once everything gets seated in you will be please with the final fit.
