Hi. Couldn't find anything in the archives so ask for guidance. I tracked my trim tab play down primarily to the mechanism that's buried between the pulley in the tail and the rocker mechanism above the inspection cover. It must be a lead screw the way it converts rotary to push-pull. Before extracting that which is probably held by the castle nut on right side of the pulley and taking out the rocker mechanism so the mechanism in question can be removed I thought I'd check with the experienced.
Thanks, Ron
Thanks, Ron
