I don't know what it will take to convince you guys. What will you accept as the final word? Here's my stab at it.
We may be arguing 2 separate issues here. One issue is whether or not our Taylorcrafts that do not have an anticollision light system can be flown at all. The answer to that is yes, they may. That is supported in part by FAR 91.205(b)(11). You all can look it up. I suspect that this is the question that Ian Twombly at AOPA answered for David Price in the other thread. On this point I have no issues.
The other issue is whether or not our Taylorcrafts can be flown at NIGHT without an anticollision light system. This is the point that I have been arguing in the other thread. I have quoted FAR 91.205(c)(3) in support of the reqirement for the anticollision lights. So far, no one has offered any reference to the contrary. All I have gotten was to take Norm's word for it.
I have been corrosponding with Denny Pollard. He is a maintanence inspector at the Oakland FSDO. As far as I am concerned, that is the final word. Attached are three letters that I received from him on this subject. In each letter, his response is first, followed by my original question.
Greg
To answer the question on anticollision lights I will need to know if the aircraft was certificated under CAR-3 or part 23 rules.
The older aircraft CAR-3 built before March 1, 1979 are usually Civil Air Regulations (CAR-3) those built after March 1979 are part 23. Anticollision lights are required on part 23 aircraft and not all CAR-3 depending on the year they were built. If they are installed they should work in accordance with part 23.1401. However having said that to operate at night ALL aircraft are required to have an anticollison light installed that works.
Part 91 covers ALL aircraft CAR-3, part 23, part 25 transport category and part 27 and 29 rotorcraft. You are correct in stating they must have an anticollision light to fly at night. Aircraft such as CAR-3 have to install them in accordance with the field approval or STC process to meet the part 91 rule.
There is no grandfather clause in the FAR's for older aircraft.
I hope this answers your question.
Denny
MBOCKELM@aol.com
To: Dennis D Pollard/AWP/FAA@FAA
03/30/2004 12:11 cc:
PM Subject: Anticollision Lights
Hi Denny.
I own a Cessna 195 and lurk on that board on a regular basis. I also own a Taylorcraft and lurk on that board, also. There is a debate going on about whether or not anticollision lights are required for night flight. 91.205(c)(3) states that all U.S.-registered aircraft are required to have the anticollision light system to fly at night. 91.209(b) states that if the system is installed it must be turned on unless ...
I have sited 91.205(c) as my proof that the system is required. The other gentleman states that the older aircraft are grandfathered under a different part of the regulations. However, he will not cite his references. He also implies that 91.205 only applies to transport category airplanes.
I have been upfront in stating that I may be wrong, but I need difinitive proof. As in an FAR reference. Can you help prove me right, or wrong, either way? As of now, I am standing by my view that the anticollision system must be installed to fly at night as per the regs I have cited.
Thanks.
Greg Bockelman
Greg,
In accordance with part 91.209(b) would require that airplanes equipped with an anticollision light system be operated with the anticollision light system lighted during all types of operations, except when the pilot determines that, because of operating conditions, it would be in the interest of safety to turn the lights off.
However part 91.205 Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition.
What this is trying to say is you have to have an anticollison light system installed for night flying. So the Taylorcraft is required by part 91 to have one installed even if it was built in 1950 without the system.
This is from the Preamble:
New ¡× 91.209(b) requires airplanes equipped with an anticollision light system to operate those lights during all operations, including daytime VFR. The incremental cost of this provision consists of light bulb replacement. The FAA estimates that a light bulb for an anticollision light system costs approximately $50 and that this provision would necessitate an incremental bulb replacement every two years. Accordingly, the cost is projected to equal $25 per year, per affected operating airplane.
The FAA holds that any grounding of an airplane due to a faulty bulb or light system will be rare and quickly corrected. The cost of such grounding will be negligible, when compared with the safety benefits of operating anticollision light systems.
In summary, the FAA holds that the benefits of the rule, though not directly quantifiable, will exceed the expected costs. Each of the provisions, as well as the entire final rule, w§c be cost beneficial.
Denny
MBOCKELM@aol.com
04/03/2004 09:21 cc:
AM Subject: re: Anticollision Lights
Hi Denny.
Thanks for your response. I think your resopnse answers my question. However, to be 100% sure, let me ask the question this way:
Can a Taylorcraft, certified before 1950 or so, legally fly at night
without an anticollision light system?
Greg Bockelman
Greg
Still requires a anticollison system to be legal at night.
Denny
MBOCKELM@aol.com
04/03/2004 10:28 cc:
Denny,
A follow up question about the anticollision lights.
Does it make any difference whether or not the airplane has an electrical system? There is the argument that if not, it does not require the AC system to fly at night.
Thanks.
Greg
Denny has made it perfectly clear that ALL airplanes MUST be equiped with an anticollision light system if they want to operate legally at night.
I don't know what more you guys could ask for in the way of verification.
Part 2 comes on Monday after I talk with Ian Twombly or someone similar at AOPA to verify some questions.
Greg
Denny
MBOCKELM@aol.com
Hi Denny.
Thanks.
Greg Bockelman
Greg,
Denny
MBOCKELM@aol.com
Hi Denny.
Greg Bockelman
Greg
Denny
MBOCKELM@aol.com
Denny,
Thanks.
Greg
