Folks - I ran into an ordering problem and can't see what I did wrong. Was hoping you could spot what happened so I can avoid it in the future.
I'm practicing repair by inner sleeve. I had some 3/4 OD tube from a previous order and planned on ordering the next smaller size to use as inner sleeve material.
Looking at the Dillsburg catalog, we see 3/4 tubing has a published wall thickness of .028 (I measured it at .03, but I'm not using a precision instrument). I figure the ID would therefore be .694 (.750-.028-.028= .694). The next smaller size tube (11/16=.680) should have slipped into the 3/4 tube by .014. It didn't, so I began measuring. The actual OD of the 11/16 tubing was .690 (not .680) and the actual ID of the 3/4 tubing was .670, screwing up the fit by .020.
Question - did I overlook something? Is this problem univeral? Is this what comes from the factory and we need to be able to adjust to?
Question - Ideally this would get turned in a lathe (don't have) I was able to clamp the tube internally and turn it in my drill press, but turning was tedious. Does anyhone have a suggestion for removing the metal more rapidly than with a file? - MikeH
