Rib stuff and forming question
  • Rib stuff and forming question
    view a rib from broadside and you see the holes (for reducing weight) and if you look just a little closer, around that hole is an indentation (name?) designed to stiffen the hole.
    Assume for a moment you have to rebuild a portion of the rib which contains
    20* of one of those indentations. How do I form that indentation? build a wood form and beat the metal around it? - Mike
    Re: Rib stuff and forming question
    Build a wooden tool and die set with a bolt through it. Maple works well. Punch the hole, put the dies in place and tighten the bolt.
    (Flanged lightening holes...)
    New Yoke hub covers
    www.skyportservices.net
      The EAA web page videos has just started a series in making a sheet metal ribs. The first of 6 clips is now on the EAA web.
      Ray
        OK, I missunderstood the question. 20* is 20 degrees.... For that a forming block and a mallet is probably the best way.
        New Yoke hub covers
