Some of you may recall that I've been having some problems with mainly my right magneto. I get a good ground runup followed by the mag going rough under load in the air. Well now its occasionally running rough on both mags and I'm beginning to think its a fuel problem.
I went to fly this morning and the right mag was very rough although as the engine warmed up it seemed to get better. But it never got good enough to fly. Occasionally it would be rough on both mags.
We wanted to look at the carburetor so we dropped the lower cowl. I noticed that the intake manifold was dripping wet with water. I figured it might have been carb ice even though we used a good deal of carb heat during the runup.
Since the right mag was rough we figured it might be a bad plug (they have just been replaced. We put the old plugs back in and it ran up perfectly. We figured the problem was solved (as we have with a number of things).
It ran up 100% on the ground so I took off. During the climbout I switched to the right mag and it was missing badly again. I turned downwind and did another mag check. This time even when I went back to both mags the engine continued to miss badly. I increased the throttle and it barely responded. It got better after that and on final I had normal throttle response again although the right mag was still rough.
Back on the ground and it ran up poorly again.
This problem has us totally baffled. It has now run the gamit of occuring on one or both mags (although 98% of the time its the right mag), high or low rpm, under a load or at idle and normal runup.
I'm thinking now that its not ignition at all but a fuel problem. Several times we have made changes like cleaning the plugs, changing the plugs, removing the washers that were mistakenly put in the ercoupe cups on the top plugs and every time we did these things it responded and ran fine only to go bad again.
The plane gets flown regularly and the gas drains without a problem or trace of contamination. Could my carb be bad?
Its on the ground now until this is resolved for sure.
Any ideas would sure be appreciated.
Thanks guys.
Thanks guys.
) broth it home installed new pluggs and it ran great. Without the covers! I reinstaled the covers and back to the boat we went.(;f
:boxing:
ops:
