aileron cable size?
  • aileron cable size?
    My aileron cable is different from what is in the specs. Does anyone know if it matters whether it's 3/32 or 1/8th or whether it matters either way
    thanks Shawn Coleman
    Re: aleron cable size?
    Hi Shawn,
    I would say it has to meet the specs/drawing.
      I thought the AC-43.13 says primary flight control cables must be at least 1/8" ??
      DJ Vegh
      www.azchoppercam.com
      www.aerialsphere.com
      Mesa, AZ
        Re: aileron cable size?
        thats what i assumed as well bigger is better but spec s say different unlees its a screw up
        not sure just wanted input my original cable is bigger and not
        3/32
        thanks for input
        shawn
        also got my new struts today so have used ones available if interested untested but sure they are fine if not would refund of course
        if interested let me know
        would ship from ontario oregon
          3/32
          thanks for input
          shawn
          Hay Shawn,
          What does the "spec" say?
          What is the "spec" that you are referring to?
            mech pulled it out of tcraft info I believe from the net unsure of the source. Anyway, we both come the conclusion that it was bad info, he also was under the impression that the bigger cable is a requirement so that is what we installed. It is good as new. Also for input my cable was wore under the -dash where it intersects the pulley everybody might want to look at that I never assumed my aileron cables would get wear marks. My mechanic says the reason is is that the routing is not exactly straight. Just a heads up, wouldn't take five minutes to doublecheck.
            shawn coleman
              YES Shawn as I explained before it is 1/8th, how could it be anything else...
                forrest ya agree just found bad info on net and wasnt sure if cable was original or not at the time
                shawn
                  okey dokey trust the good information , I sent you the info on the struts thank you very much. bye Forrest
