Need rudder arm (steers tail wheel) mine has a 11/16" shaft. The ones listed in my catalogs have a 3/4" shaft. Any help would be appreciated. Fred
Need '46 BC-12D rudder arm
Re: Need '46 BC-12D rudder arm
If you have a good shaft there might just be someone here who has a drawing and picture of a really solid one made up from the original shaft and some 1/4 inch bar stock. Where did your's break? Think he would tell you that it works perfect and is considerably stronger than the original.
You would need to have some machining and welding done. Was pretty simple I hear.
I bought one of the 3/4 inch ones. Thought about cutting it down. Cast aluminium. Scary.
DarrylLast edited by flyguy; 04-02-2008, 00:53.
I bought my rudder arm from univairLance Wasilla AK
