Parking brake doesn't lock.
  • Parking brake doesn't lock.
    When I twist my parking brake handle clockwize, it doesn't lock the cable. Is there something that needs to be replaced? Is there an adjustment to be made?
    Thanks in advance,
    Danny Deger
    Re: Parking brake doesn't lock.
    mine is the same way. I suspect there are some teeth or something that are worn.
    Where can new or good used parking brake parts be sourced?
    DJ Vegh
    www.azchoppercam.com
    www.aerialsphere.com
    Mesa, AZ
      It is a simple device , look at it the teeth need filed and the little wire needs replaced, ONLY trust it to RUN across the ramp to get chocks , OR carry them with you.
      taylorcraft@neo.rr.com
        Can't trust the parking Brake!
        No I dont but I do this if needed.
        I use a heavy load type bunge cord and hook it around the brakehandle and over to the stay by the door. Then pull the handle again and puch on the brake pedals.
        My brakes will hold to 1100 - 1200 rpm what way.
        Also the controls are tied up full back and trottle set and LOCKED!(;f
        My trottle is set to give idle as I pull it full back, no fiddleiling to to find idle possition.
        I use the above method when I can not find a starter or tie down the tail!
        Len
        Foundation Member # 712
          Len
          For starting without the tail tied down, I have two chocks with a line tied between them and a line from the left chock that I attach to the pilot door handle. One chock in front of each wheel. After starting I stand at the pilot's door and pull both of the chocks in and off we go. Some times I have to push back on the plane to relieve the tension on the chocks.
          Danny Deger
            I have worked on my parking brake many times and I am still very wary of it. I only use it when the engine is OFF and I am going to tie it down.
