Just when I thought my annual was about to be wrapped up my IA calls to tell me he needs to tear into the wing to replace the right tank. It leaks. And according to the TCDS a BC12-D MUST have the right wing tank. He won't sign off unless the right tank is functional.
is there a way around this? I never use the wing tanks anyway. My flying is always local.
But I would definitely argue that the TCDS clearly calls out the MAXIMUM fuel capacity as being 18 gallons, IF the nose tank and OPTIONAL LEFT wing tank (per note 2) are installed. This and only this interpretation would explain why the end note allows a wing tank as an ELIGIBLE option. If on the other hand a wing tank was mandatory and part of the REQUIRED fuel, it clearly COULD NOT not have been listed further down the page as eligible or optional!
