welding question: fill in the gap?
    Re: welding question: fill in the gap?
    Someone suggested that instead of attempting to view this as get-the-inner-tube-molten-then-include-the-outer-tube that I just treat this as two seperate lap joints. Thoughts? - MikeH
    Please see http://members.cox.net/mhorowit/cluster/lapjoint/
    I took someones suggestion and treated each side of the "outer sleeve" and the "inner sleeve" as the components of a lap joint; hence two beads.
    - MikeH
    PS - I don't think taking a shortcut by simply cutting a partial slice in a larger diameter tube would make a difference in the exercise.
    As I post this, I see the "High Time Cub" posting - will read over coffee
      Now, if someone were to say "let the outer sleeve burn back", problem would be solved. - MikeH
      "As we said, the diameter of the puddle will vary, but that variance will be much smaller than you think. It will always be about 1/4 inch and may widen out to 5/16 inch or even larger on acute-angle joints in clusters, but that's a function of the joint configuration and the bead bridging a gap, rather than the metal or torch tip.
      Incidentally, it is because the bead is so wide in relation to the thickness of the material that it is difficult to get a bad weld, as long as it penetrates and doesn't get too hot and oxidize. Since we are working metal .035-063 inch thick, if we get penetration into the surface and the bead is 1/4 inch wide, we've got a tremendous amount of weld area in relation to the thickness of the metal. So, as long as there actually is penetration, the weld will be good. Period."
        This will take several reads;
        I like the first part 'cause he's saying something I've observed when welding and around a campfire - when the coals burn down and you focus on the fire, you can actually feel like you are part of the settling coals - I"ve heard this refered to as "dreaming the fire". Exactly the same mesmerizing that the author talks about with the welding puddle - you get drawn into it; I"ve had to look at the puddle out of the corner of my eye to avoid going into 'stare' mode. I've been taking my glasses off when I put the goggles on - I like the idea of cheap reading glasses 'caue I also like the idea of getting in close. Thanks for the pointer - MikeH
