Bungee Tool
  • Bungee Tool
    Sometime ago I saw a message from someone who builds and sells a bungee tool that works on the BC12D and I can't remember who it was. I need a tool to put new bungees on my tcart. Help! Paul
    Re: Bungee Tool
    Hey Paul,
    Have you had any luck on locating a bungee tool? I have one I made, it works great. If you would like to borrow it, let me know.
      Re: Bungee Tool
      Paul I'm in Visalia, CA. If my tool is repaired you can borrow it.
      559 901 3621
      L Fries
      N96718
      TF#110
        Re: Bungee Tool
        Paul,
        I am in Central Texas and have a tool you can borrow too.
        Buell Powell TF#476
        1941 BC12-65 NC29748
        1946 Fairchild 24 NC81330
          Re: Bungee Tool
          I have been told that a sissors jack will work. Weld a pin on the top to pull on the bungee and then roll it off when it is streched. I have one that I am going to modify. Could probably pick a jack up at the junkyard for a few bucks.
          Kurt
            Re: Bungee Tool
            There is one on e-bay also
            Buell Powell TF#476
              Re: Bungee Tool
              Paul has been taken care of regarding a bungee tool. Thanks.
                Re: Bungee Tool
                A few years back I mentioned a easy way to replace bungees if the windshield was off the airplane. A 2x4 accross the top with a come-along and a bent hook will pull up the bungees allowing them to be easily slid off the hook onto the support. Worked very well for me.
                Dick Anderson
                  Re: Bungee Tool
                  Carl Rigdon, my phone died since we last spoke so I lost your phone. Check your PM. Thanks, Larry
