I've used a Garmin-90 for quite a few years and it does everything I need in the Taylorcraft - it's small, has the aviation data base, and I get 14 hours or so on a set of Duracells. If I were to upgrade I would have seriously considered the 92 (12 channel receiver) but they are out of producton now so the Pilot III is the next choice in the smaller units. I have flown with a 195 and they are nice but go through batteries very fast. If you want the high end of the portables go with the 196 - color takes more power to run.
I still use the 90 but have recently acquired a GPS-18 (remote sensor intended for automotive or marine applications) and run it through my iPAQ with an aviation moving map. It's a 12 channel receiver and works great if you don't mind a lot more cables in the cockpit! I've always had trouble on the ground at my home airport - the ATC radar seems to zap any GPS signals until I'm away from the airport. The GPS-18 still gets 9 sats on the ground and usually 10-12 in flight.
As far as whether or not to use a GPS in a Taylorcraft - I know I wouldn't have flown half the trips I have if it wasn't for the GPS. I always have a sectional with me for backup but the GPS makes life a lot simpler. I agree that on short local flights there is no need to have it on, just nice on trips.
Jim Zangger
1946 BC12-D NC94953
Cedar Rapids, Iowa
Jim Zangger
1946 BC12-D NC94953
Cedar Rapids, Iowa
