EDO 1320 Float rigging
  • EDO 1320 Float rigging
    Does anbody out there have welded on float fittings that can take a picture of the rear strut rigging of their 1320's? I have a set that I purchased that had been installed on a t-craft with bolted on fittings and it looks like I will have to machine a new piece to bolt to my welded on fittings. It appears I need to make a fork type fitting on my rigging in place of the aluminum block that is currently bolted to my float strut.
    Thanks
    Joe Shallbetter
    Re: EDO 1320 Float rigging
    Joe,
    I'll take a picture of mine tomorrow and post it, It's very easy to build a set and weld them on, I 've welded on a number of of them.
    Wolf Lake Aircraft Services
      Here's some pictures of the strut on the rear of the float and of the attach fitting on the plane.
        Thanks for the pictures but whats on my airplane is a flat tab not the ushaped bracket.
        Joe Shallbetter
          Where can I get a drawing of the EDO 1320 floats and attachments parts for my BC-65? I have not purchased the floats yet but I am set on the 1320's and I want to install any brackets and pulleys I can before I cover it so I do not have to cut the fabric later.
