Does anyone know where to get info on correct metal prop for 65 lycoming prop
  • Does anyone know where to get info on correct metal prop for 65 lycoming prop
    I want to change from a wood prop to metal to improve High altitude performance. Do not seem to know where to look for prop specs.
    Re: Does anyone know where to get info on correct metal prop for 65 lycoming prop
    Jack,if your going to sell your wood prop I know a guy looking for one. Let me know. Thanks! Eric
    Eric Richardson
    1938 Taylor-Young
    Model BL NC20426
    "Life's great in my '38"
    & Taylorcoupe N2806W
    TF#634 :tup:
      I would sell , if I get a metal prop. thanks
        I would expect it to be in the TCDS. If not then you need a feild approval. Does that help?
          Most of the catalogs like wag aero have manufacturer's recommendations for cruise, climb, and standard props. I think some of the manufacturers are online also.
            check www.sensenich.com they list the metal prop 74ck-2-38 for a taylorcraft bl65. Hope that helps
            Ken #375
              TCDS lists that same prop model, see excerpt below.
              Sensenich M74CK-2, fixed pitch metal 21 lb. (-46)
              (Lycoming 65 hp. engine only).
              Static r.p.m. at maximum permissible throttle setting:
              Not over 2400, not under 2250. No additional tolerance permitted.
              Diameter: Not over 72 in., not under 68 in.
