Stiff Ailerons
  • Stiff Ailerons
    I bought my BC12-D last June and have always thought that the ailerons seem
    too stiff and hard to move even while on the ground. When I had my annual
    inspection done this month, I asked the mechanic to diagnose the problem.
    He disconnected the ailerons and checked all the pulleys and the cable tension
    but the controls still were stiff on the ailerons. He finally tried loosening up the
    bolts that hold the universal joints together (behind the panel) and found that
    they were binding the control movement! Now the airplane is a joy to fly!
    So if any of you have the same problem, this could be the solution. Has
    anyone else the the same problem?
    Fred W 44051
    Re: Stiff Ailerons
    No, when mine gets stiff it's usually the oil "drying " out in the belcrank shaft in the wing.
    FYI- There is an oiling hole in the top of the part that the u-joint shaft goes thru, I oil that once a year.
    Dave.
