Interesting thing I have seen on the cross-country tracks laid down by two different GPS units. (see how smoothly I avoided saying GPSes.) My cheapo Magellan will lay down a completely different track/course for a long cross country as compared to the Garmin I checked, between the same airports. Example: Central Calif (Los Banos) to Atlanta. The Garmin will give a great circle path that goes up to Kansas and then back down. The Magellan will draw a track to follow down across Oklahoma or Texas, much further south that is, and definately not a great circle. When you check it out over a shorter range the Magellan exactly tracks a straight line drawn on a chart. I have flown right down the track and checked visual checkpoints along the way. Interesting. It gets better though.
If you set a waypoint on a sharply defined peak that is say 100 miles away, like Mt. Shasta going up the central valley, the Magellan will take you off in a curve and then curve you back in to the waypoint. That is compared to the direction that you can see goes directly to the peak. The times I have checked, it was off to the right.
I think I know what is going on but it is just a little more odd than I would care to put in print without someone who knows about this confirming.
Anyone know anything about this or can refer me to an expert site or reference book. There is nothing in any manuals that I have seen.
