Oil streaked belly
  • Oil streaked belly
    Finally been doing some acro in my Swick T-craft. Actually went to an IAC competition at the Flying W in NJ this past July.
    I thought I read in one of the TOC news letters about using tampons around the exit of the oil breather tube to reduce the oil stains on the belly.
    My T-craft does not have inverted fuel/oil, so it's a daily chore wiping the belly after practicing aerbatics. I saved all my newsletters, but cannot find the article relating to using absorbant material around the oil breather.
    What's safe/legal? My Swick is NON experimental. I don't mind cleaning but it does get old.
    Does this article jogs any ones memory?
    Thanks
    bob sabbatino
    Re: Oil streaked belly
    My '38 will be 69 years old this year.I think she's beyond the tampon stage.LOL
    Sorry I just couldn't resist!:joy:
    Eric Richardson
    1938 Taylor-Young
    Model BL NC20426
    "Life's great in my '38"
    & Taylorcoupe N2806W
    TF#634 :tup:
      Try running the breather into a baby bottle instead of out the bottom of the cowl. That way you only have to empty a bottle instead of wipe the belly down.
      Jason
      Former BC12D & F19 owner
      TF#689
      TOC
        One airplane I owned had a small Veg-All can loosely mounted on the end of the breather hose to catch the oil. You just dumped out the can after a couple of flights.
        On a certified airplane I would not use a Veg-All can... probably malt liquor or something
        Most mechanics would not have TOO much objection to a small 6 oz. aluminum can suspended by safety wire, and not able to get in the way of anything that moves. You can always remove the "V-8 Jiuce" printing and polish it to look like an airplane part
          This is a fix a lot of us have used. I made one up and get no oil on the belly. It was originally designed for the C150 aerobat:
          Just checked and can't get to the site, so follow the directions to get there and you'll find out how to make an extension for your breather.
          Ed@BTV VT
          TF 527
            I have run the breather clear down to the landing gear axle, OR back and out the tail; OR use the can method.
              have one on my f19 run it full 6 qrts all the time belly is clean
              shawn coleman
              ontario or
