needed - tailwheel leaf springs
  • needed - tailwheel leaf springs
    I've had a set on back order from AS&S for over a month now and I get calls every week saying the new expected ship date is 1 week away. At that rate eternity will end before I get the leafs.
    I need some bad. who's got a new or nearly new set for sale???
    DJ Vegh
    www.azchoppercam.com
    www.aerialsphere.com
    Mesa, AZ
    Re: needed - tailwheel leaf springs
    Try univair or wag-aero
    Your tailwheel shimmy will go a way with the new properly arc-ed springs installed.
    Still having fun with your plane?
    Jason
    Former BC12D & F19 owner
    TF#689
    TOC
      HELL YES!! I've been averaging flying once daily since you brought it here except for the week it was down for a new exhaust pipe install last week.
      DJ Vegh
      Mesa, AZ
        Is there something that shows what the geometry of a "properly arched spring" is supposed to look like?
        Richard Boyer
        N95791
        Georgetown, TX
          Some useful info on tailwheel setup
          Jason
          TF#689
          TOC
            snapped
            well... today the main leaf snapped plane is grounded until I can muster up some leafs somewhere
            DJ Vegh
            Mesa, AZ
              Re: snapped
              Try Univair.
              At Univair, we’re experts at salvaging and rehabilitating classic planes with our vintage aircraft parts for sale. You can buy classic aircraft parts here!
                Re: snapped
                Try Univair.
                nope... nada... nuthin. And from what they said when I called this morning it will be several weeks. This really stinks. Perfect flying weather and my damn leafs are busted. just typical.
                DJ Vegh
                Mesa, AZ
                  Did you check with Wag Aero as Jason mentioned? Don't know if they have them in stock right now, but they did when I got mine there a while back.
                  Here's their 1 1/2" wide BC12D Tailspring link.
                  Good luck...
                  NC29624
                  1940 BC65
                    yup! just called them and it's on its way! they had ONE set left
                    DJ Vegh
                    Mesa, AZ
                      Is it a leafspring similar to what would be used for a Maule Tailwheel? I have a brand new one that I paid 100 bucks for at Aircraft spruce, only to convince my A&P the next day that I didn't need to re-arch my spring, i just needed to fix the tailwheel bushings and rebuild the full-swivel mechanism.
                      I would part with it for 70 bucks plus shipping. I don't know if it would help save you from univair or wag.
                      Jeff
                        leaf springs arrived today and she's all back together and flying. What a difference!!! the tail sits about 5" higher now with the new springs and the shimmy is gone for good.
                        The Matco tailwheel is great as well. Swapped it out with the Scott non-swivel. Going to make ground handling here on the crowded ramps much easier.
                        DJ Vegh
                        Mesa, AZ
