cross controling on floats......why?
  • cross controling on floats......why?
    Firstly Hi ! I haven't been around this site for a while.
    My experimental Tcraft with C90 and 1650 floats performs well but I still find that I have to cross control in turns and it feels very unnatural . I'll enter a
    coordinated turn with Aileron and rudder but very quickly the turn becomes too steep and continue to increase unless I use aileron to correct. In order to maintain the correct bank angle I hold the rudder in the desired angle and then cross control with aileron to hold the angle of bank.
    Anyone have a ventral fin they want to sell ?
    TKS, Robert
    Robert Bradbury
    BC12D Experimental
    C-FAJH C90
    Sen. 74X39 prop
    Seaplane 1650 Floats
    Re: cross controling on floats......why?
    I assume you checked the rigging on the float rudders. If those are out of whack it can cause similar symptoms. That's a pretty long set of floats for a T-craft so there is a lot of moment arm on the water rudders.
    Another question. Are you just having to hold opposite control forces or is the aircraft actually in a slip/skid? ie is the slip indicator out of the cage in a stabilized turn?
      Yes the ball is over to the side and it does feel like a slip/skid. I'm thinking as you are that the floats are the root cause and that a ventral fin should solve the problem .
      I did check the rigging to be centered with the rudder.
      Robert
      Robert Bradbury
      BC12D Experimental
      C-FAJH C90
      Sen. 74X39 prop
