Any experience with "spot blasters"?
  • Any experience with "spot blasters"?
    Has anyone had experience with the group of hand-held sandblasters commonly called "spot blasters". They sell anywhere from $15-50. - Mike
    Re: Any experience with "spot blasters"?
    I have one, they are mostly good for removing rust pits that go thru a painted flat surface, for instance around the key lock in a door. Good for spot repairs, not good for anything larger than say a square inch in my opiniion. Body shop stuff.
    If you want to sand blast, you need 5hp compressor or better, and either a siphon or pressure pot sand blast setup. And the safety gear. I tied them all, and now for anything bigger than a wheel, I take it all to a pro and let him deal with the mess, cleanup and sand down your collar.
    My opinion anyway.
    bob.
    Bob Ollerton
      Mike,
      I bought a WW Grainger blaster that holds a quart or two of sand. It hangs from a shoulder strap, has a plastic holding tank for the sand, and has a 48" hose and nozzle. It draws the sand out of the hopper via venturi suction. Works good.
      I use it for small jobs when I can't get into a crevice or corner. It works great on even a small compressor because you usually won't blast for more than 30 seconds or so.
      Also consider a small benchtop blast cabinet. I bought one from Harbor Freight for $100 and use it all the time for small parts. I run it off of a 1 hp compressor. It uses steel shot.
      John 3728T
        Originally posted by jdoran View Post
        Mike,
        A look at the Grainger catalog doesn't show a direct match to what you're describing. Is this the item to which you are referring? - Mike
          Sears sells one that has about a 5 gallon capacity hopper on a small dolly. I blasted some large parts with one. Worked well but it's messy and you have to cover all of your flesh or it's paifull.
          Winston L.
          Winston Larison
          1006 Sealy st.
          Galveston TX, 77550
            Winston L.
            I have a full sized sandblaster (less convient compressor); was looking for something for those small places; about :30 seconds of blasting (and I have a tank that will provide that, I think) - I can always leave the big rig near the compressor during the week I guess. - Mike
              Mike,
              Yes that's the blaster I use.
              It's cheap, easy to use and perfect size for small to medium jobs.
              You know I operate in saltwater, and corrosion is my biggest worry. I use everything from a dremel tool with teeny wire brushes to sandblasting, a pneumatic die grinder with wire brushes etc to stay on top of rust.
              Another thing I use a lot is a roll of emory cloth. It works good on tubing to really clean the metal prior to primer and paint.
              It seems that every job requires a different tool or technique when it comes to cleaning rust. It really helps to have a collection of tools and consumables.
              John 3728T
