new baffles for C-0200
  • new baffles for C-0200
    I am rebuilding the Continental 0200 in my F-19 and my old baffles are pretty much shot and I would like to know who I can buy new ones from. Thank you, Jack.
    jack
    Re: new baffles for C-0200
    Good luck with that one. If you find out the answer would you please share it with the rest of us?
    SkyHigh
      Do you think the factory might have them. They are suppose to be using the 0-200. in the sport plane.
      Robbie
      TF#832
      N44338
      "46" BC12D
      Fond du lac WI
        The TaylorCraft factory was the first one I contacted but haven't gotten an answer from them yet. Thanks. Jack.
        jack
          I recall that we had an incomplete set of baffles for the 0-200 on the first Taylorsport. We had to fabricate from the templates at least one of the baffles.
          It would probably be helpful to the parts dept at the factory if you could email a photo of each baffle. They may have to search for the template and alot of the templates look very similar.
          Mike Rice
          Aerolearn
          BC12D N95910 Tale Dragon
          TF #855
            Thanks Mike, I'll call the factory and see what they say. Jack
            jack
              If all else fails, you can use the baffles from some other similar airplane (Champ, Ercoupe) and modify the outer shape to match the T-craft cowl. Although I haven't done it, I would assume that much of the change in shape can be absorbed by using the wider silicone baffle seal material.
                Thanks Bill, I haven't had any luck out of the factory so am looking at suppliers for Cessna 150's which have the 0200. Jack.
                jack
