Too long cross country
  • Too long cross country
    Well, I had one of our missionary pilots here for training prior to his departure for New Guinea and the day after he arrived a situation arose where we both needed to get to Kansas City for the funeral of a mutual acquaintance. If we drove or flew commercally it would take too large a chunk out of our training period so we decided to fly ourselves. The Cessna T-210 was down for maintenance (as usual) so we went in the T-craft. We were literally getting in the plane to leave when one of the jury strut to wing attach fittings broke off. This seemed like a pretty important item to address so we robbed one off of Yellow Duck's wing which is still not needed due to it being disassembled. Twenty minutes later we were off. Got as far as Dickson, TN and stopped for the night. Sure am glad they still paint the names of towns on water towers... Anyway, the weather was nasty and we didn't get out of there until after 17:00 the next day. Went as far as Sikeston, MO and spent the night again. In the morning the ceiling was 300' so we didn't get off until about 10:15 and were able to make it into Hiawatha, KS before dark. (11.5 hours logged)
    On the return we left at dawn and made it the whole way to Concord, GA about 25 minutes before sunset. We could have done better but had to deviate into Alabama to avoid convective weather. (10.1 hours for the return flight) The plane ran ok on the 100LL although it isn't used to it. The trip up was all at low level and on the way south we flew at 9,500' cause it was over 100 degrees on the ground. Overall, I think it was probably like a backpacking trip. The longer ago it was, the more enjoyable... We had ground speeds as low as in the 50's and never got one of those elusive tailwinds. My guy did a fine job of navigating with a map, plotter, whiz wheel and watch. (Yes, it still works guys and gals...)
    Re: Too long cross country
    "If you've time to spare go by air",means even more in a Tcraft.
    Eric Richardson
    1938 Taylor-Young
    Model BL NC20426
    "Life's great in my '38"
    & Taylorcoupe N2806W
    TF#634
      We live and learn, I trusted a refuler on satuerday and had a fuel cap on a wing tank replaced with the tube pointing rearward.
      I did not check it on the walk around becuase of on lookers at the flyinn.
      As I am closing in on home I deside to top up the main and it would not fill.
      I know right away what had happend.
      I did have 45 min reserv + 30 min in the main and 30 min to home, so I was OK but a landing to change the cap was a thought what passed trought my mind. As I slowed up to let down at my home airport the fuel moved.
      ( 60 - 65 Mph) I dont know if I last any fuel through sifoning but is is posible.
      Usealy I refuel my self , but at the flyinn a lot of things was going on-------
      Just a reminder for me and some else now to keep your mind on the task at hand This kind of supprice one don't need! Front: is going to be painted on the cap at next visist to the plane as well just in case!
      One don't want to be rude when a person asks questions about the plane and flying. I try to take them away from someone else what is doing a walk around as I find it disturbing. So why did I not-----
      Len
      Foundation Member # 712
