Prewar Covering Cost
  • Prewar Covering Cost
    Just a quick note to update the group. I stripped the covering off the RH wing and was thrilled to see the excellent condition that everything appears to be in. I hope the left is as nice. The rear spar has a small aluminum tag nailed (approx center span) to it that appears to be a part#. Was this "normal"?
    I just ordered the entire "kit" to cover my 1938 BF. I stopped shopping when I talked with Jim and Dondi at Aircraft Technical Support. It was a VERY pleasant experience to work with Jim and Dondi! Both were extremely helpful in answereing the numerous calls and dozens of questions/pros/cons pertaining to choice of coverings.
    Basic kit was $2950...by the time I added envelopes, epoxy primers, covering tools, the thinner and topcoat (for all but fuselage) I was up to $4000.
    I finally started using the "search" function on the site here and am sure impressed with the wealth of knowledge that is available to the group.
    Thanx to all!
    MIKE CUSHWAY
    1938 BF50 NC20407
    1940 BC NC27599
    TF#733
