Ok, so for a while I have known that a Tcart with a 85 has a little problem with flat out full throttle speed. I've come to understand that there is just too much lift that you have dump by getting the tail way up and then you're dragging the fuselage through the air sideways (vertically.) So today I learn something new that makes perfect sense, but I had never carried the logic on out to that point. I was checking minimum power to hold altitude at the lowest drag speed. After that I climbed to 8,000 just to check speed again at the 75% power at full throttle altitude. Found 67 statute mph indicated to be my best steady climb rate. At 7,500 it was holding a steady 500 ft/min.: Maybe 75*F on the ground. Nice. You really have to keep the wings level and the ball centered though or it will drop right off. That is with a "cruise" 71 inch prop.
So at about 8,300 I set the power to 2000 rpm (not sure why, except I've been putzing around at that setting lately what with avgas at $4 per.) and do a couple of runs in both directions checking the GPS ground speed.
Amazing: at 2000 it averages out to 97 statute. AT 2000 rpm! And then the bell went off. (I can hear some guys thinking, well duh.
) I had really been complaining in my beer about the 85 not being much faster than the 65's I've had. Now I understand why. I get 850 ft/min consistently up to about 2000 ft, but the power doesn't make it go much faster down low. Now I find you don't have to be going flat out to get the same effect with the fuselage drag, even a fast cruise wipes out the efficiency. So, the plane doesn't like to fly much over the indicated equivalent of 97 true at 8,000. Dummy me I didn't write the indicated down but it may have been between 85 and 90. But the indicated airspeed is the trick. At some altitude, above 8000 ft, the wing will be flying at the best angle of attack to make the fuselage trail straight back at the lowest drag angle, at full throttle rather than 2000 rpm say, and it is really going to honk. And it will be the same indicated as the best down lower. Amazing.
Just gotta do a few more tests flights, and then I can start working on the mixture control to get it functional. Great fun. I are a test pilot.
) I had really been complaining in my beer about the 85 not being much faster than the 65's I've had. Now I understand why. I get 850 ft/min consistently up to about 2000 ft, but the power doesn't make it go much faster down low. Now I find you don't have to be going flat out to get the same effect with the fuselage drag, even a fast cruise wipes out the efficiency. So, the plane doesn't like to fly much over the indicated equivalent of 97 true at 8,000. Dummy me I didn't write the indicated down but it may have been between 85 and 90. But the indicated airspeed is the trick. At some altitude, above 8000 ft, the wing will be flying at the best angle of attack to make the fuselage trail straight back at the lowest drag angle, at full throttle rather than 2000 rpm say, and it is really going to honk. And it will be the same indicated as the best down lower. Amazing. Just gotta do a few more tests flights, and then I can start working on the mixture control to get it functional. Great fun. I are a test pilot.
Maybe a German Diesel? Normalized to 15,000 ft. Wouldn't help down low, but up high, oh my.
