N21271 ???
  • N21271 ???
    Does anyone have any idea as to the history of this plane- I have checked the FAA registry and it comes up as a Cessna with no other history. I think it was a 1938 Tcraft but I am not sure.
    Eric Minnis
    www.bullyaero.com
    Clipwing Tcraft x3
    Re: N21271 ???
    got a ser# e-mail me direct [email protected] . It probably is in another souce of mine by N number will check.
      Re: N21271 ???
      Forrest- I recently got some stuff and there was a rudder included. It was still covered in what I thought to be original cotton. The tailwheel steering horn that normally goes into the tube on the bottom is not present- the tube is sealed and there is a clamp on steering horn. It is definately a pre war- I was just curious about it's history. When I removed the covering I saved the covering and plan to hang it in my airplane room.
      Eric Minnis
      www.bullyaero.com
      Clipwing Tcraft x3
        Re: N21271 ???
        I guess you have the rudder of NC21271, that ship was Ser# 1064 a BF-50 built in 1939 , the split was ser# 1135 & up in 1939. No more info at this time, you can call FAA Aircraft records and have them check the archives for that NC number....
          Re: N21271 ???
          Forrest- Thanks a million. I could not find anything in my computer systems but had not called registry.
          '39 BF-50. . . . . thanks!
          Eric Minnis
          www.bullyaero.com
          Clipwing Tcraft x3
            Re: N21271 ???
            Forrest, are you using Juptner's? 'cause he agrees with you. Maybe my data plate is weird but: 20442 sn-1130 has Jan. 5th 1939 on a Taylor-Young plate.....? And Eric's would be a '38 with sn-1064.????
            20442
            1939 BL/C
              Re: N21271 ???
              Yes I used Juptner , I will check what you say with MY factory "B" book...thanks
                Re: N21271 ???
                Could it be that originaly the tailwheel was in the fuselodge like the A model or they used a A model rudder and added the rudder steering? Marv
                Marvin Post TF 519
                  Re: N21271 ???
                  If you guys think about it for a minute you'll remember that in the late 1930's I think they still used a skid.
                    Re: N21271 ???
                    According to Juptner? Here is an incomplete corresondence of Ser # to N-# for TC-696.http://vb.taylorcraft.org/attachment...8&d=1118389415
                    and http://vb.taylorcraft.org/showthread.php?t=1576
