A special thanks to Jerry Self for letting me study his BC12D and taking up a good part of his day. You're a good man Jerry! I promise I won't tell anyone that you live in Shelby, NC and that you have a great grass strip that is just begging airplanes to land on it. Does anyone know where to find the plastic fairleads for the BC12D rudder and aileron cables. ( It might have been R. Lees web sight that I saw them). Also, the "D" window on the BC12D. How does the frame install on to the fuselage. and how does the window itself install? Do I cut my own from plexiglass? Someone lead me by the hand! Also, the 12 gal gas tank in the fuselage had the filler neck come all the way out. I think that the tank is aluminum and the neck is for sure steel. Any ideas on how to put it back together-- welding--gluing?
Fairleads,Windows, Fuel Tanks
Re: Fairleads,Windows, Fuel Tanks
I have the print, but you need the stamped AL frame. email me and I will send you the [email protected]Fred Johnson
N44467
N96662
TF#97
from what I can tell the "D" window frame was originally designed for the pre war aircraft with the smaller doors. SO fitting it to a post war with the all alum door moves it back a bit and the diag tube that runs under the frame on the early ships now runs across the window when installed. Check out Rob Lee's rebuild pics for a better description.
Jason
N43643Jason
Former BC12D & F19 owner
TF#689
TOC
My tcraft was built in dec 45, certified 01/03/46, has cloth cover doors and metal door frame with wood only on bottom of door frame. Will the prewar windows fit? GeorgeTF# 702 Don't be afraid to try something new. Remember amatuers built the ark, professionals built the titanic!
Any Taylorcraft is welcome to fly into 29NC.Originally posted by Dan CarlsonA special thanks to Jerry Self for letting me study his BC12D and taking up a good part of his day. You're a good man Jerry! I promise I won't tell anyone that you live in Shelby, NC and that you have a great grass strip that is just begging airplanes to land on it. Does anyone know where to find the plastic fairleads for the BC12D rudder and aileron cables. ( It might have been R. Lees web sight that I saw them). Also, the "D" window on the BC12D. How does the frame install on to the fuselage. and how does the window itself install? Do I cut my own from plexiglass? Someone lead me by the hand! Also, the 12 gal gas tank in the fuselage had the filler neck come all the way out. I think that the tank is aluminum and the neck is for sure steel. Any ideas on how to put it back together-- welding--gluing?Jerry in NC
TF# 114
Prior BC12-D's
N43433
N95823
N44024
