N29544 Slips the Surly Bonds!
  • N29544 Slips the Surly Bonds!
    After a three week repair that took 6 months... an STC upgrade that took 10 years (off my life)... and about 3 major episodes of a wife wanting to kill me... 1940 Taylorcraft N29544 s/n 2387 left the ground yesterday without major incident.
    No leaks from a re-plumbed fuel system. No leaks from the A-65 that weren't expected (bottom of pushrod tubes 2 drops, bottom of oil screeen one drop...perfect). No carburetor malfunctions resulting in engine failure on takeoff (been there, done that 2 takeoffs ago). No control system failures after loosening and re-tightening the aileron circuit.
    We made three smash and dashes, smelling for fuel vapor and feeling around under the fuselage tank for fuel leaks. On the fourth downwind abeam we departed the pattern for Agua Dulce airport 20 miles away. The airspeed indicator was 15-20 mph too high, because I put in a new pitot line and pitot tube, and then used the inside of the cockpit for a static source. It appears that the inside of the cockpit is slighlty lower than static pressure...oh well I had the world's first 115 mph BC-65 for a while Will make other arrangements for a static port shortly.
    In looking through the aircraft records today, I found that I had bought a real rarity of an airplane. s/n 2387 had copies of the entire chain of ownership from November 1940 to the present! It was first sold to an FBO at "Los Angeles Municipal Airport", before it became Mines Field and then Los Angeles International. I don't think we'd be welcome there anymore!
    One interesting mystery I found is that the original weight from the factory (original statement of conformity, Ray Carlson signature) was 664 pounds. The brochure minimum was 641, and this one was built with dual ignition, 2 doors, brakes, tailwheel, etc. making it "664 pounds with installed extra equipment". Several years later, another document (an annual inspection/application for yearly airworthiness cert) lists the weight as 641. But I cannot imagine that someone converted this airplane back to single ignition and removed the brakes, etc. etc. to bring it back down to the brochure weight that was less than when it was built. The last weight and balance in 1997 listed empty weight at 806, but 2 days ago I had two professional aero engineers with high end electronic scales weight it and it came out at 776. This is still heavier than I had hoped, although it includes a metal prop, interior upholstery, a 1/8" thick aluminum plate instrument panel (why the hell ???), a radio, my skylight, two wing tanks, and Stits instead of Irish Linen.
    With the 1280 pound gross after the STC mods, I still have 500 pounds useful, but there's still some weight in there that I can't figure out. How this airplane lost 30 pounds by adding a fuel tank, radio, and a skylight is beyond me.
    But... the damn thing flies straight and floats on landing just like it's supposed to. Other than $3.69 a gallon for avgas at my home airport, it was a fantastic day. Tomorrow I hope to fly again
    Re: N29544 Slips the Surly Bonds!
    Congratulations...! I know the feeling! Dick
    Dick Smith N5207M TF#159
      Big Congrats. know the feeling. Isn't it great ?
      Lee
      Yellow Duck
        Wow!
        Great; and thanks for the narration - Mike
          Well finally! That is great news... the standard static port is out in the wing ( no ice) and stick it straight out into the wing by the leading edge, to adjust stuff you can move it a bit. have the small hole into the back of the instrument. Weights! egads here we go again, lots of times when they had heavy production going, they did not weight each ship... Then at one time the fabric only had three good coats of dope ( 6 put on light at right angles). WE have always found the original weights were off . The brouchure wt was a SWAG and used by some mechanic later on in its life. With the electronic scales of today , you get what you get.... move on in life and enjoy your fine bird... My father flew the BC12D with 90 HP Franklin with very fine prop at 2200 Gross out of the old factory....Experimential ship for the four place Model 15.... don't askhow many shock cords..
            Congrats VB - Great to hear the news. I hope that my 3 mo. re-rebuild doesn't take that long! Bob
              Yahooo another air craft back in the air. I tell the history to LAX airport management just before an Airport open house or airshow or tell P.R.O. on his or her good day. Bring a sign with the historyof the aircraft and maybe you get in? Experts call it PR. It's real name is B-S, but just like Bucklyes Mixture it works!
              Good luck and enjoy!
              Also take your wife for a NICE ride, in the plane or to a resturang of Her shoice.
              After all, we fly by the grace of our wifes and the Lord.
              Len Petterson
                Bill
                Congratulations on the project completion. I recently completed a BC65 restoration and coincidently it also weighed in at 776 and I have only one wing tank, an 1/8" thick panel, skylight and ELT. Even at the higher than expected weight, I am amazed at the performance for a 65 HP.....runs circles around my 7EC with a 90 HP, cruise and climb. Still trying to get use to the landing flotation and tendency to balloon on me......so much different than the champ. Wheel landings are definitely the way for me to land it in any crosswind.
                Gary Snell
                TF #403
                BC65
                N27524
