first pics after pulling some fabric off
  • first pics after pulling some fabric off
    I don't think the plywood trim tab is a stock item
    Zoom in and check out that crack. It goes more that 1/2 way arround the tube.
    Jason
    N43643
    Jason
    Former BC12D & F19 owner
    TF#689
    TOC
    Re: first pics after pulling some fabric off
    Neat Pics! Looks like you have your work cut out for you. Checked out the other pics also, awesome country you live in. Thanks!
    David and Judy
    TF# 651
    Butterfly Fun Lines
    1941 BF12-65
    N36468
    Grasshopper Fun Lines
    1988 Hatz CB-1
    N83LW
      Jason, your trim tab is an early Model D tab. I don't when your ship was built but it may have on your ship from day one. The rest of your tail is also model D. Dick
      TF #10
        Jason:
        Great photos! Keep em coming.
        My BC12-D also had a plywood trim tab. It looked perfect, but when I removed the fabric I found the plywood underneath was completely rotten. The whole thing just crumbled to dust! I had to use the old fabric as a template to make a new plywood structure.
        Looking at the photo of the crack in the lower tail section. Do you think the damage was a result of rust or from a "Hard landing"?
        Bob Gustafson
        Bob Gustafson
        NC43913
        TF#565
          That crack almost looks like water had frozen in the tubing and split it.
          20442
          1939 BL/C
            (looks at the picture, looks at his torch)
            (hangs up the torch)
            (sighs)
              Jason,
              Sometimes it can sure make ya shiver when you find out whats been hiding under that 35 year old fabric...don't it.
                J-
                Thanks for showing us the pics. Im sure glad to know someone else is out there at the same level of rebuild that I'm at. I just aquired NC43011 about 30days ago. So far I don't have any of the problems you have. 011 was a west Texas BC12-D.
                Would you mind sharing your vision for your ship? I dont have an engine yet but I'm thinking about the c-85 using the harel STC.
                Sloanlow
                Jim Allison
                  So far I know that I am going to need some of the "C" channel used to make the ribs in the horizontal stab. Looked through my Spruce catalog and didn't find it. Both elevators and the trim tab need some work. Anyone have a serviceable set for sale to help speed up this rebuild?
                  Jason
                  N43643
                  Jason
                  TF#689
                  TOC
                    Jason
                    N43643
                    Maybe that C-channel is more of the Dahlstrom extrusions that Mike H and I ran into.
                    - Carl -
                      WOW! That photo of the 300 foot STOL strip shaped like a flatiron is awesome! I'm jealous.
                        Hello: As a graduate of Saint Martin's University in Lacey, WA, you made me very homesick for the Pac NW. I have uncovered '46 BC12-D Deluxe N43306 and found light rust on the tail feathers but not the level of corrosion ssen on yours...reflects the difference in climate as I am in South TX now. My '46 has a metal trim tab and actuator that is similar to a replacement trim tab actuator that I have from a '40 BL65. Good luck on your recover and a quick return to theose beautiful woods and mountains! I also liked your engine installation...my A65 is ready to reassemble. Doc
                        Doc TF #680
                        Assend Dragon Aviation
                        FAA Senior AME #20969
                        EAA TC #5453 / FA #1905
                        CAF Life Member #2782
                        "Leben ohne Reue"
                          [QUOTEJason, your trim tab is an early Model D tab. I don't when your ship was built but it may have on your ship from day one. The rest of your tail is also model D. DickQUOTE]
                          Hey Dick,
                          My plane is a 46' s/n 7302 first flight 3/30/46. Are the post war tail feathers the same as the Model D? None of my Tcraft books show the horizontal stab as having diagonal ribs like mine. Any advantage one way or the other? I should be able to use the all metal trim tab (1673-1) right?
                          Jason
                          N43643
                          Jason
                          TF#689
                          TOC
                            Hey Dick,
                            Jason
                            N43643
                            Jason
                            TF#689
                            TOC
                              Threw a few more pics up in the gallery
                              Jason
                              N43643
                              Jason
                              TF#689
                              TOC
