Forrest brought up the use of "Lionoil" in the "Phenolic Spar Bushings" thread.
I did a little reseach that I'll pass on what I found. I quote from "A/C Maintenance" Brimm & Boggess 1940,
"Lionoil is a proprietary artical, but as it has such widespread use in the aircraft industry, it may be diccussed here. It is a clear amber colored liquid, much similar in appearance to clear varnish. It's greatest use is for protective undercoats. It may be used successfully on all kinds of metals and woods. "Lionoil" has replaced varnish as a protection for wood to a considerable extent.It is used for the interanl protection of steel tube structures and is applied by blowing the fluid through the structure with compressed air and then allowing it to drain out. Clear Lionoil may be cut or reduced with turpentine or naptha. NOTE: Never use gasoline. Two to four hours are required for it to dry dust free and from 12 to 48 hours for it to set permanently"
I also found at one site on the internet that says Lionoil was a mix of 50% varnish and 50% boiled linseed oil.
I'd really like to hear some other input on this....maybe some of you may have used it in the past...
