When using a metal prop on a tapered flange crank with prop hub, should you use the metal front cover plate that is ALWAYS used with a wood prop? or just washers under the prop bolt nuts and no plate. I was told that using the cover plate would cause corrosion on the prop.
Jason
N43643
Jason
N43643
