I'm looking for a way to get a sensing on the condition of fabric.
(put aside for a moment that it's not a bad idea to remove the fabric after 30 years to see what's being hidden)
Although the theoretical lifespan of the fabric is way out there, it sounds like 20-35 years is what the Millers expect. This being on a hangered a/c and/or with adequate UV protection and good maintenance of the coating.
And we know that just because the seller says it has always been hangered, he might not know what the previous owner did.
So, I propose the following. Move the a/c into a well-lit area. Crawl in and face aft, looking down the inside of the fuselage. Have someone cover the windscreen and windows with blankets or something to block out the light.
See if any light comes thru the fabric. If no, then the fabric is well protected and probably will go a full 35 years.
How many years does it have already? If it's got 25, then you probably have 10 years to play with.
Anyone see anything wrong with this approach? - Mike
- Mike
