Exhaust and heat shroud
  • Exhaust and heat shroud
    Hello, I need a new exhaust and most probably a heat shroud for my BC12d.
    Any sugestions which one; maybe stainless steel, and where to buy it? TKS
    Re: Exhaust and heat shroud
    I started this and then lost it so must re write it and that is never the same.
    I purchased a SS exhaust system from Sonny Porch fit good except for the heat shroud connection, but a little mod and that will be ok. The good part it is two parts and so do not need to remove engine. Looks great. He probably has the heat shroud thing corrected now tho. You can ck with him. Cost about $550 or so.
    Now the heat shrouds, I purchased mine from Univair, cost about $700 for a simple piece of Alum ( actual three pieces) Looks good and should perform as it should.
    Pictures are on my site : http://groups.msn.com/TaylorcraftYellowDuck
    You can go there and look at both under Yellow Duck.
    Lee
    Yellow Duck
      That SS exhaust looks great! I have to replace mine too.....is that a correct replacement? Meaning, if I replace it with the SS, would I have problems come annual time?
        You will need to speak with your IA on that. Call me at 337-367-0070, and we can talk about that.
        Lee
        Yellow Duck
