Wood prop
  • Wood prop
    where can I get wooden props inspected or redone?
    Re: Wood prop
    The Sensenich folks in FL reconditioned mine - Mike
      Re: Wood prop
      Once you see what a nice job they do you may not want to put it back on the plane to get all messed up!
      gusc
      N5123M
      '46 BC-12D
        Re: Wood prop
        Right!
        I need to blacken the pilot's side, but I think I'll sit and admire it for a while - Mike
          Re: Wood prop
          I never blackened mine. It is only a problem when the sun is low and directly behind you and not really much of a problem then. It is a shame to paint that beautiful varnish black. It is also so slippery when fresh that black paint might not stick so well.
          gusc
          N5123M
          '46 BC-12D
            Re: Wood prop
            In the early days of WW2 They painted the wood props black or OD but soon discovered that they absorbed so much heat that the props warped. Dick
            TF #10
              Re: Wood prop
              This is the first time I have heard of this......Mine is just varnished. I have never had a problem with visibility and actually thought it looked cool when the sun hit it just right an I could see the arc!
              Richard Boyer
              N95791
              Georgetown, TX
              Richard Boyer
              N95791
              Georgetown, TX
                Re: Wood prop
                I do most of my flying early Sunday morning, so the sun is behind me on a left base for 27.
                The stroboscopic effect mesmerizes me. - Mike
                  Re: Wood prop
                  Perfect opportunity to hypnotize yourself! Any bad habits you need to get rid of?
                  Richard Boyer
                  N95791
                  Georgetown, TX
                  Richard Boyer
                  N95791
                  Georgetown, TX
                    Re: Wood prop
                    "Flicker Vertigo" normally happens facing a low sun but I guess you guys are especially talented! It is avoided by not staring at the prop. Some of my students were hypnotized by the runway on their first few landings!
                    A strobe effect (Prop appears to stop) can be simulated on the ground at night with a fluorescent light directly in front of the plane with the rpm at numbers divisible by sixty, 1200 and 1800 are easiest. This is an excellent way to check your tach accuracy. An incandescent light may work too, I never tried one. It just has to by 60hz power.
                    gusc
                    N5123M
                    '46 BC-12D
