Trim Cable
  • Trim Cable
    I need to replace my trim cable, what size is it? Can I get it from Aircraft spruce?
    Jonathan
    Re: Trim Cable
    I think it's 3/32 possibly smaller? don't know the exact length, but I would imagine 30' should do, and yes AC spruce should have it in stock.
    Jason
    N43643
    Jason
    Former BC12D & F19 owner
    TF#689
    TOC
      Re: Trim Cable
      Trim cable size is 1/16" and 30 feet will be enough.I think you can do it with 25 feet but you will be cutting it close.It is better to have a little extra then to come up short.
        Re: Trim Cable
        This is where I got my cable based on an earlier post at this site. David Loos was very helpful. The 7x19 cable is very flexible. Bob
        "1/16 (7x19) trim cable is readily available from the mfgr Loos & Co, Pomfret Ctr, CT, 06259, U.S.A. The cable is mil spec. Be sure to ask for a certificate of origin. 32' cost me around $12 US. I'd like to suggest that you contact David Loos (related but not the mfgr at "[email protected]") to help you with your order. Loos & Co is one of about five US companies making mil qualified cable supplying the industry mostly through retailers like Spruce and others. David helps as a local distributor."
