On the ferry flight home with my brand new 1940 BL-65, I noticed that the trim would spring back to a certain level at cruise. I'd try to push it down a little further to relieve forward pressure on the yoke, but it would spring back. I could trim it nose up for landing OK, but when I got into high speed cruise (94 blistering miles an hour), it just sprang back a bit. 1000 miles with a pound of forward pressure required on the yoke.....
I also noticed that there was some fairly large deflection of the trim vane, and this probably creates some extra drag we don't need.
Does anyone here know what or where to tighten this up so it has more friction?
Does anyone know if it is advisable / possible to simply enlarge the size of the trim vane by 10% so you get the same trim force with less deflection and drag? I know this would officially require some paperwork, but I also know that the field inspectors do not normally carry the pre-war T-craft trim vane drawings with them
