Help with STC/337/??????on BL-65
  • Help with STC/337/??????on BL-65
    Background- Basketcase, some work previously done (15 wing ribs instead of 13, wing fittings beefed per Harer STC, no wing tank , ready for cover)
    Other changes per me- Ski lights, Harer STC baggage area, Cessna 150 gascolator, 5/16 fuel lines and valving per Harer, Cessna 150 muffler on left only for cabin heat. Add one wing tank. I want to retain the lycoming o145-b2.
    What we have here is all of the Harer STC, less the engine change, plus muffler, gascolator, and ski lights.
    Question is: What is the easiest way to accomplish these changes legally? Thanks in advance,
    Don Hernke
    Re: Help with STC/337/??????on BL-65
    What gross weight did you want to go for? With that engine you have to stay with 1150 or 1200 why did you go to the -2 fittings. & the 5/16 lines and not upgrade to the 85 HP?
      I would like to go for the 1200lb. gross weight. The Lycoming came with a fresh overhaul from El Reno aviation, and at this time do not want to spend the money on a 85hp.
        Don,
        You can check on STC's by going to
        http://www.airweb.faa.gov/stc than by TC.#700 or by Taylorcraft.
        They are not all there, because I couldn't find the Poly Fiber STC, but
        in there Manual, your BL-65 is listed.
        Hope this helps,
        Don
