Gravel Bar
  • Gravel Bar
    My buddy Marc and I went out and hit a few "bars" this weekend. Follow the link to check out some of the pictures he took.
    Jason
    n43643
    Jason
    Former BC12D & F19 owner
    TF#689
    TOC
    Re: Gravel Bar
    like the pic's cant wait untill summer ice and snow here now....
    Lance Wasilla AK
      Re: Gravel Bar
      Jason I would think twice before landing there. I stick to my wet lands in good old Louisiana. Pictures look great.
      Vic
      N95110
        Re: Gravel Bar
        Hi Jason! Thank you for the pictures,they look similar to areas that I have been in and out of. I use 8.50's and I am careful about frequenting areas that you have shown. I think it is hard on the machinery and a steady diet of it is detrimental. Your friends airplane is better suited for these operations,in my opinion. A good test of limits though!? Any one else care to share their thoughts?
        Jim
        Jim Hartley
        Palmer,Alaska
        BC12-D 39966
          Re: Gravel Bar
          Those are the biggest rocks I would ever try to operate on. That trip was a test, I now have something to mesure against for operating on gravel bars. We have plenty of bars around here with the smaller 2-3" rocks + sand. I figure if I can't push it on the ground the rocks are too big!! The portion of the bar used for TO/LNDG is much smoother. As always I appreciate the input from all the members here.
          Jason
          N43643
          PS - What PSI do you use in your 8.50's Jim Hartley?
          Jason
          TF#689
          TOC
            Re: Gravel Bar
            I keep the tail up as long as possible, and Yes! it is kinda bumpy on the 4-6" rocks. A good preflight is done prior to departure everytime. Flying off gravel bars is not for everyone, knowledge - skill - judgement!!! If any one of those is lacking the potential for mistakes rises greatly. The aircraft must also be properly equiped and in good condition. Always take 2 planes incase one has a problem.
            Jason
            N43643
            Jason
            TF#689
            TOC
              jealous
              Jason,
              Great pictures...I'm jealous. Looks like you guys had a blast.
              Northwestern Lousiana (where I'm at) has to be one of the worst places in the country for trying to land off-airport. We've got 80' tall pine trees or swamp...take your pick. There is some farm land around the Red River, but it's all private property.
              The guy I bought my F-19 from used to fly it to Alaska every summer and he made some cool videos, shot from the plane, of himself taking off and landing on gravel bars up there. He did break the tail-wheel off once. The plane still has a little crinkle in the bottom of the rudder to prove it. What would worry me isn't so much the tail-wheel or the main gear (stuff that can be fixed), but possible fatigue where the wing struts attach to the fuselage. If that subsquently gives way in flight...you're pretty much screwed. I don't know if there's any known cases (on any type plane) where repeated gravel bar landings (or any type of jointing) cracked the strut attach points. (It think Forrest Barber described an incident where a T-craft on floats had an attach point give way a long time ago). I would think that the bigger and softer the tires, the less you'd have to worry.
              Brady
              Brady Glick
              N3614T F19
              N4417E F21
                Re: Gravel Bar
                PS - What PSI do you use in your 8.50's Jim Hartley?[/QUOTE]
                I do not know if the gauges are correct or not Jason,but the way I do it is to inflate to just fill them out and then I stand on them and bounce up and down with my body weight.I try to feel just a little give or compression. the thumb test as well...just a little give... Generic tire gauges show about 10 to 15 pounds. Seems to work well for me.
                Jim
                Jim Hartley
                Palmer,Alaska
                BC12-D 39966
