Stuck/Stubborn Propellor
  • Stuck/Stubborn Propellor
    Not that it shouldn't be expected but went to remove the propellor from my project last night and it won't budge. BL 65 wood Sensenich propellor that hasn't been removed since it was installed, if I am reading the log books correctly since 1957. Suggestions ?
    Clark Freese
    1940 BL 65, Project
    Re: Stuck/Stubborn Propellor
    Never mind, steady light flat tapping with rubber mallet all around the hub released it. Now for inspection and correction. no deformities seen, some areas where varnish is gone and wood discolored. Depression in wood at hub cover plate side of 1/32 or less. will use feeler gauge later to determine exact depth. Fingernail just catches.
    Clark Freese
    1940 BL 65, Project
