Quick back story - Plane sat out of annual for a little over a year as I tried to find a new mechanic. Thorough annual completed December 2014, flew 2015, sat 2016. I would go out an start it from time to time. (Probably not frequently enough)
Found new IA, he came out recently to do the annual. I went out and drained the old gas out of it a couple of days before, added new gas, and started it up (used primer to start). It didn't want to idle. Seemed to run fine above 1000 RPM. Drop just a bit below 1K and it would quit.
We took the carb apart cleaned it out (didn't see anything to explain the issue). New seal kit for the carb, back on the plane. Same issue.
Tightened the nuts I could get to on the intake tubes (at jugs) and checked the hose clamps on the inner and outer intake tubes. Same issue.
Carb came off again. Went through it again. Paid special attention to tiny idle holes. Back on the plane. Same problem. BTW used the method of turning idle mixture screw out 3 full turns from closed as baseline. Then tried out and in a bit from there.
Now removed primer from the system. Couldn't even get it started as primer was needed to get it started before to get it to the 1K RPM throttle setting to keep it going. Keep in mind it would start with prime with slight throttle. So when it quits or won't start without primer at that throttle setting, it tells me it isn't getting idle fuel.
We haven't replaced the intake seals yet, but I purchased some in case it was necessary. Looks like it may be a little involved to do so.
I feel like we have addressed any low hanging fruit. What are your thoughts?
