Howdy Tribe.
Hope everyone had a great Christmas. I had a very interesting experience today @ controlled Airport. I made a call about 10 miles out and the controllor advised that the active was 17 but with the winds being variable, I had my choice of 17 or 35. Since I was approaching from the Southeast and 35 has a right pattern I inquired about a modified base to 35. The tower said call 2 mi out. I called and was cleared for an extended right base for landing 35. I inguired about the wind and was advised it was still variable @ 5-6 Kts and I should advise when turning final. Turned on final and made the call.
All was well until just after the flair. That variable wind I mentioned earlier-well, it varied!!!!! Just before touchdown I added a little right rudder and the nose moved to the left and without thinking(which is common for me) I added some more right rudder and the nose moved a WHOLE BUNCH to the left and the nose came up! Now, I'm 45 deg off the center line and nose up and thinking broken rudder cable. Then an old instructor's advice hit me-Never make a down wind landing in a light tail wheel airplane because the rudder inputs may become reversed.( funny how you can cover so much ground in your mind in such a short span of time.) Anyway, I figured what the hell, I'm in the neighborhood-try the left rudder because at this point it can't get any worse-Low and behold about 1/2 pedel of left rudder and she straightened out and dropped in almost perfect!!! I taxied to an off ramp and called ground and 5 min later the fuel truck is in front of me and I'm telling the ramp boy to top off the header with 100LL and that I would be in the coffee shop. I order a cup and as the girl went to get my coffee, an elderly gentlemen set down next to me said that he had just observed my landing. I commented that it got real interesting just before touchdown. He laughed and said that must have been your first downwind landing in a Taylorcraft. I advised him that it was not only my first but it was also going to be my last. As it turned out, he was a retired flt instructor and had learned to fly in 41 in, of all things, a Tcraft. We spent the next 2 hours talking Taylorcrafts and flying and this Fri, I'm going back to Enid and he and I are going flying.
So, here is a situation that could have been a disaster that turned out well.
But, Hell will freez over before I ever make another down wind landing!!!!!
What if you stalled the plane? Your stall speed is going to be the same, but your ground speed will be stall + 40! So my ground speed in this instance would be 88mph! In the air, who cares? But on the ground, this is a completely different animal.
