Disc Brakes & Wheel Pants?
  • Disc Brakes & Wheel Pants?
    Is there anyone who has done the upgrade to the Grove wheels and disc brakes who has afterwards installed wheel pants? I have my wheel pants, the ones from Wag-Aero that are the M-050 000 model, and I just received approval from the Montana FSDO (it only took 9 months) to install the grove wheels & brakes. My guess is that there is no way that I will be able to use my wheel pants after this upgrade. The work may not be done very soon and I just want to know if anyone has made both work.
    Charles
    Re: Disc Brakes & Wheel Pants?
    Charles,
    Please do us all a favor and once you get your FSDO field approved 337, scan both sides into a pdf file and post on the Reference Document forum that was recently started here on this site.
    While it is not technically "approved data" it certainly can be helpful in getting other FSDOs the confidence that it is an improvement that should be available to all who want to make the investment.
    Thank you.
    Larry Wheelock, '46 BC12D N96179 presently under repair, A&P/IA TX
