Help!!!
  • Help!!!
    Dear Friends:
    Wheels of my Taylorcraft were stolen. I�ve got four half wheels to form two complete wheels (less brakes) but I lack bearings, washers, axle nuts, bolts and nuts to assemble the wheels.
    I just need the parts bo bring fuselage with engine rolling behind a pick-up to my house.
    Anyone can assist me with these parts?
    I need:
    Two 08125 Bearings
    Two A6075 Bearings
    Two 6CP75 Washers
    Two 6CP35 Washers
    Two 6CP34 Washers
    Six 6CP27A Bolts Assy
    Six AN310-4 Nuts
    Two AN320-12 Nuts
    All in used condition, if not usable for certifiy a plane is OK.
    Many thanks. Have alls an nice year.
    Miguel.-
    Re: Help!!!
    Miguel,
    Check your private messages on this forum.
      Re: Help!!!
      Thanks, Pearson
      I take note of your info, and will write.
      Miguel.
        Re: Help!!!
        Is that your real name? I am a Miguel too!!!! LMAO
          Re: Help!!!
          Yes, Michael,
          This is my real name.
          Happy hearing of you.-
            Re: Help!!!
            Now, I am needing only:
            Two 08125 Bearings
            One A6075 Bearing
            Two 6CP75 Washer
            Two 6CP35 Washer
            Two 6CP34 Washer
            Two A500 Washer
            Two AN320-12 Nut
            Parts must be used, not airworthnes, only needed for rollin fuselage on wheels to home.
            Miguel.
              Re: Help!!!
              Miguel,
              Creo que tengo todo lo que necesitas. Acabo de comprar ruedas nuevas (con chumaceras y todo)
              Dame tu direccion, y puedo mandartelos.
              Tim
              Tim Hicks
              N96872
                Re: Help!!!
                Miguel,
                I think that I have what you need. I just bought new wheels (with bearings and everything), so I can send you the parts from the old wheels.
                Send me your address and I'll send them to you.
                Tim
                Tim Hicks
                N96872
                  Re: Help!!!
                  Tim:
                  Many thanks. Please look your PM.-
                  I will treat of send one.
                  Miguel.-
                    Re: Help!!!
                    Miguel,
                    Below is a picture of what I have.
                    The top two rows of 13 parts is what came out of my old wheels.
                    The bottom row is some stuff that I found in the boxes to the left.
                    The large cup seems to be the right size for the wheel/bearing.
                    I couldn't get the large cups out of the old wheels.
                    I didn't find the nuts, but I'm pretty sure that I have some somewhere.
                    So if I'm missing one large cup, do you want all these other parts?
                    I got your address.
                    Un abrazo,
                    Tim
                    Tim Hicks
                    N96872
                      Re: Help!!!
                      Tim:
                      The top two rows items are OK, are all I need.
                      Not problem with nuts, I can do locally here.-
                      Thanks and hugs.-
                      Miguel.
                        Re: Help!!!
                        Listo, Miguel,
                        OK, I sent all of the stuff in the picture above.
                        Check your PM on this site for the tracking number.
                        Hopefully it will help you out of a tough spot.
                        Un abrazo,
                        Tim
                        Tim Hicks
                        N96872
