Wing compression struts
  • Wing compression struts
    Im in need of 2 wing compression struts to rebuid a set of wings. Needed for a BC12D 15 rib wing but they may be the same for prewar wings as well. call 319-721-2437 or a pm.
    Re: Wing compression struts
    Walter,
    My prewar has (3) different length comression struts in each panel. You can search threads on this discussion. Make sure you get the right length.
    MIKE CUSHWAY
    1938 BF50 NC20407
    1940 BC NC27599
    TF#733
      Thank you fro bringing that to my attention,the 2 that I need are the very last ones on each wing at the wing root.
        Do you have a measurement? I have several.
        Ray
          I will get back with you, Thanks
