Engine parts A65 thru 0200/Wood prop
  • Engine parts A65 thru 0200/Wood prop
    A65 cylinders standard do not need boring. ?
    0200 crank 10 under fresh yellow tag, ECI in box. 2000.00
    0200 case w/yellow tag. Nickson's the oldest and finest. 1000.00
    0200 cylinders chrome w/ yellow tags and rings. Pistons?
    Wood prop for A65 near perfect. Sensenich 72x44 800.00
    Selling for family member
    Re: Engine parts A65 thru 0200/Wood prop
    Can you give more info on the cylinders? IE, number available, history, etc.
    Thanks
    Blake Carlson
    Crookston, MN
    1941 BC12-65
    N47665
    Member #1009
      I will need to pull them from the self. I suspect you are interested in the casting #'s? The history is normal, the 0200 needed reman, the A65 I pulled apart 18 years ago to freshin up the lower end. The oiil pressure came up to slowly and I never finished the project.
        Have not made it to the shelf yet. Forgot......four of each.
          If you have the logs for the O-200 case I'll buy it.
          I'm in Bulverde.
          Best Regards,
