I Need Prop and Mounts..and more...
  • I Need Prop and Mounts..and more...
    I am putting an 0 200 A in the BC12 D. Need advice.. ..and prop ? Need engine mount rubbers.., Cowl Blisters, and suggestions on exhaust system...
    Re: I Need Prop and Mounts..and more...
    Luscombe 8E/8F exhaust is the best way to go,several props are available(check STC's),do you want to use the cone mounts like is on the A65's or the Cessna 150 mounts. If you want the cone mount adabtors like you are using on the A65 then contact Ed Athey,he sells a complete kit which makes it very easy. PM or email me and I will give you his contact info. The cowl blisters are harder to find. You might make a set or the long ones like used on the Ercoupes will also work,those can be found in ACS.
      Original style cowl bumps, composite construction, $48 per pair
      Bob Gustafson
      NC43913
      TF#565
        Where can these bumps be found?
          I used the Wagaero cowl bumps and they work fine. Made of alum. 27.50 each.
          Wade
            T-Rex:
            Use the "private message" function to give me your mailing address,... I'll send you a set of cowl bumps.
            Bob Gustafson
            NC43913
            TF#565
