gas cap
  • gas cap
    I have a matching set now so this one is available.
    Jim
    Jim Hartley
    Palmer,Alaska
    BC12-D 39966
    Re: gas cap
    I'm intersted, Jim. Sending you a PM.
      Re: gas cap
      Hi Marty, it appears that your mail box is full. You can call me at 907 376 6062.
      Jim
      Jim Hartley
      Palmer,Alaska
      BC12-D 39966
        Re: gas cap
        I just realized then when you sent the message. I cleared out a few messages if you want to sent again. Thanks.
          Re: gas cap
          A word of caution on these caps.... Drill a small #50 hole facing aft Ii.e. 180 degrees opposite of the tube opening. I learned the hard way... if a bug builds his nest in the tube, there is no other way to relieve tank pressure/vacuum when the valve is closed. You could wind up with a tank like mine... or worse... zero fuel flow when you need it.
            Re: gas cap
            That's real ugly Terry. Pretty hard to see in a short compact tube as this style of cap and this one does not have the hole at the 180 position. I take the caps off and blow through them to make sure they are open.
            The cap is still available...$40.00 plus shipping.
            Jim
            Jim Hartley
            Palmer,Alaska
            BC12-D 39966
              Re: gas cap
              Jim,
              I have sent you two messages stating I would take that and asking for shipping costs. Please check your messages. Thanks!
                Re: gas cap
                Marty, $45.00 will do the trick.
                Thanks, Jim
                Jim Hartley
                Palmer,Alaska
                BC12-D 39966
                  Re: gas cap
                  Jim,
                  That is fine. Please e-mail your details to: 94thaero (at) gmail and add the .com to the end of that. I will send you my info when you contact me. Thanks.
                    Re: gas cap
                    Jim,
