TG-6 TAYLORCRAFT GLIDER CRASH, Central Arizona
  • TG-6 TAYLORCRAFT GLIDER CRASH, Central Arizona
    For a link to this story with pictures go to:
    This particular TG-6 crashed 13 ½ miles north of Echeverria Field (near Wickenburg, Arizona) on November 3, 1942.
    While conducting a dual-towing mission a BT-13 glider tow aircraft released two TG-6 gliders at an altitude of about 1000 feet over “unsuitable landing terrain” (sagebrush and 15-to-20 foot saguaro cactuses) when he became alarmed after his ship lost about 200 feet of altitude in a down draft. Thinking he was about to lose control, he cut both gliders loose. They were tied together by the tow rope, and the glider pilots were unable to release the tow cable due to an improperly designed release hook (since the cable was dragging aft it would not release off the front of the hook).
    The gliders had to land in formation as they were connected together by the tow line. The dragging tow rope on the second glider caught on a small tree causing the glider to skew 180 degrees and make a crash landing, injuring the student pilot’s pelvis. The cable tore off the first glider allowing that plane to land safely with no injuries.
    The following damage occurred to glider number 42-58634:
    1.) Longerons, formers, and stringers of entire fuselage assembly bent and twisted beyond economical repair.
    2.) Inter-cockpit push-pull torque tubes bent: both elevator and aileron.
    3.) Left and right axles bent.
    4.) Cockpit cover formers bent.
    5.) Right horizontal stabilizer bent.
    6.) Front canopy frame bent and glass broken.
    7.) Tail gear broken off.
    8.) Front cockpit step broken.
    The tow pilot was blamed 100% for using poor judgment in prematurely releasing the gliders and leaving them to their own demise. Although he appears to have been very inexperienced (a civilian pilot of Arizona Gliding Academy) – he had just 64 hours in the BT-13.
    Re: TG-6 TAYLORCRAFT GLIDER CRASH, Central Arizona
    That link shows TG-6 prototype known as the "prone ship" with the pilot laying down to fly it. Fore runner of the LBT-1 Glomb.
      Dave, I'm sorry about getting back to about the data plates you found. They are from the same ship. Hope this helps your research. I have really enjoyed your research. It fills some more holes. Dick
      TF #10
        Hi Dick , great talk today. Lets do more soon!!
          Thank you Dick Huish!
          I thought they may be from the same ship because they were found close together. It must be very rare to have two master data plates from the same plane. I'm still trying to ID some other parts I discovered and I hope to get back out to the old airfield and make more discoveries. I will search for the crash sites of some of the gliders.
          Does anyone know the part number prefix for Taylorcraft TG-6 gliders?
          Or just Taylorcraft in general and are there any Taylorcraft specific inspection stamps? If I find more parts I want to be able to ID them.
          Thanks
          DaveT
