Echeverria Field TG-6
  • Echeverria Field TG-6
    During an aviation archeology investigation of Echeverria Field, located near Wickenburg AZ, used by the Arizona Glider Flight Academy WWII, several interesting items were discovered related to Taylorcraft aircraft. See enclosed photographs. Two data plates were found. The first was
    U.S. Air Corps Type: TG-6, Serial Number: 42-58594, Order Number: W535AC-29841, Date Accepted 9-25-42The second was
    Taylorcraft Aviation Corporation, Serial Number: 6033, Model: ST-100, Date Mfg: 9-15-42, A.T.C.: 11, M.A.A. Plate No. 33280.
    What information can you tell me about these two data plates? The second plate does not match the AAF serial numbers. I believe that the serial number is the manufacture serial number. Can you tell me which AAF serial number this plate matched up to?
    Furthermore, a large section of aircraft was discovered. I did not locate any part numbers on it, but it did have 2 inspection stamps, “HT” and “23”. Can you tell me what aircraft it goes to? I know that several aircraft were used at Echeverria Field. Possible aircraft that match the large part found include: Taylorcraft TG-6, Laister-Kauffman sailplanes or BT-13 or BT-15 tow planes.
    Several other small parts were found including and access panel, wing tip lens, instrument part and small pieces of aluminum all located at a dump site near the hanger. Can you ID any of these? I can send higher resolution photos if requested to another email address.
    I already know that in World War II the Army Air Forces recognized a requirement for a simplified training glider for beginning instruction of pilots who would go on to fly troop gliders in combat. The quickest solution was to modify existing civilian light aircraft designs to serve as gliders. The Piper, Aeronca, and Taylorcraft companies each modified one of their designs for Army use. The Taylorcraft offering was designated as TG-6 and was modified from the company’s L-2 Grasshopper. Modifications included a redesigned nose that replaced the engine with a seat for an instructor, slightly enlarged tail, and redesigned landing gear with a skid under the nose; wing spoilers were fitted and the fin area increased. The modifications for the prototype were done in only nine days. The Taylorcraft model number designation for this aircraft as a glider was ST-100. The ST stood for Stanton-Taylorcraft. This was in recognition of the help Charlie Stanton and the CAA engineers had provided. The U.S. Army ordered 250 of them (AAF S/N 42-58561 through 58810) with the designation TG-6 (training glider 6).Do you have any more interesting history of the TG-6?
    Any information concerning these questions would be greatly appreciated.
    David Trojan
    Re: Echeverria Field TG-6
    Dave, bear with me. I have enough data that I can check the serial number cn relationship. I am in the process of restoring sn 6127. Dick
    TF #10
      Dick, Need Parts? I plan on returning to the abandoned field soon. Anything I can do to assist your efforts to restore one, I'm happy to help. Also any idea what the yellow glass lens fragments went to? I believe there is the ground launching apperatus still at the site where they hooked a jeep up to a cable to the glider and pulled to launch gliders from the ground. Nice old orginal hanger still standing after all these years. If only those walls could talk. I plan on writing a story about the place featuring the TG-6 glider.
      DaveT
        WOW, Forrest checking in too!! My father & Bill Crawford tested all the TG-6 in Alliance at the Taylorcraft factory. One would tow the other with a Stearman PT-17. The G-6033 was tested by William A. Crawford, on 9-18-1942 for three flights with a total of 45 minutes. My father Alden L. Barber was the tow pilot. I too will be doing more research..... HI DICK!!
        Dick is the ultimate guru on the gliders... check out the other link showing the other TG-6 replica flying It was made from an L2-M , ser#5615
        I will check to see if Dad or Bill flew it!
        My Dad flew G-6028, 29, 30, 31, 32, 34,35 etc.... just missed 33...
        taylorcraft@neo.rr.com
          What is a Taylorcraft ST-100?
          MIKE CUSHWAY
          1938 BF50 NC20407
          1940 BC NC27599
          TF#733
            Never mind...I went back and read what I should have in the first place.
            MIKE CUSHWAY
            1938 BF50 NC20407
            1940 BC NC27599
            TF#733
              On November 12, 1942, TG-6, 42-58594 was involved in a mid-air collision on takeoff at Echeverria Field with Stinson L-1, 41-19035; category 3 damage to both a/c. The glider's pilot was James D. Block and the L-1 pilot was William J. Wingfield. This accident report is on order and I'll let you know more details when received.
